- Joined
- Aug 14, 2021
- Messages
- 8
- Reaction score
- 4
Hi all,
We have been using the 3CX Desktop App since V18 for a while now and are realy happy with it.
The only thing that is not working as it should is the Jabra integration when there are more than 1 devices attached.
For example: I have a Jabra PRO 930 device and a Jabra Speak 510 for handsfree conversations.
When both devices are connected and turned on, 3CX Desktop App is not able to use the side-button to pick-up or end a 3CX call.
When I remove the USB cable of the Jabra Speak 510, the side-button on the Jabra PRO 930 works fine within the 3CX Desktop App.
I have tried multiple Jabra Direct versions but I get the same results.
The only thing that does work is to turn off the Speak 510 and then turn it on again while the 3CX Desktop App is still running.
Then, the side-button on the PRO930 works to pick-up and end a 3CX call but after restarting the 3CX Desktop App it does not work anymore.
Does anybody have any idea if this is a 3CX or a Jabra issue?
Because it was working fine with the previous PBX (SwyxIt), I guess it's 3CX ?
Regards,
Regards,
