3CX Desktop Windows Client
kforfa
Can anyone confirm that the 3CX client for v12.5 is compatible with 3CX server 15.5?
not very likely.
the answer is NO, it is not
Reactions: stefanprasch
OK....Thanks!
The answer is YES! I have used Client version 12.5 with server 15.5.
But the problem is that you will keep on getting the pop-up that says "An update is available for download" like every 2-3 secs, literally!
And you wont be able to take it beyond a certain point, and you will have to update the client because it will get irritating.
I had upgraded the clients to the latest version and they are way better than the 12.5 but the reason why I know it will work is because on the test system I have, I kept the client on v12.5 to see how it will react and trust me, it is a pain to keep the client in the older version.
Bastion Advisory
