3CX FXS V20
nerminat0rrr
I am currently having trouble with setting up a Grandstream HT802 and when I try to upload the config the password webpage doesn't upload nor it gets registered.
I have upgraded the firmware and factory reseted does anyone have any other recommendations for another device that works better.
I am currently on Telnyx and we have faxing enabled on that side.
You shouldnt have any problem..
are you able to log in to the gui at all before you try any importing?
use a different browser.
x1515
