- Joined
- Apr 8, 2025
- Messages
- 3
- Reaction score
- 0
We migrated from a self-hosted 3CX installation to 3CX Hosted over a year ago and have experienced persistent provisioning problems since the migration.
The hosted provisioning service is returning historical handset configurations, some of which appear to date back eight to ten years.
We have compared the configuration displayed within the 3CX administration console against the actual provisioning file downloaded directly from the hosted provisioning URL.
The downloaded configuration contains entirely different information, including:
This affects multiple handsets. We have been working around the problem by manually configuring handsets for over a year, but the situation is becoming increasingly problematic. We are now also seeing multiple CM302001 SIP authorisation errors, although we have not yet established whether these are directly related.
As the incorrect information can be reproduced by downloading the provisioning file directly, this is independent of the handset, its firmware, the SBC and the local network.
I suspect that legacy static provisioning files may have been retained during the migration and are taking precedence over dynamically generated configuration files.
Unfortunately, as we are using 3CX Hosted, we do not have filesystem access to investigate or rectify this ourselves.
- Extension names and usernames.
- SIP authentication usernames and passwords.
- Extension IDs.
- BLF and programmable button assignments.
- Phonebook URLs.
- Has anyone else experienced this following a migration to 3CX Hosted?
- Is there a mechanism to remove obsolete provisioning files and force regeneration?
- Can the 3CX hosting team investigate this?
- How can customers report a suspected defect in the hosted service without purchasing a technical support ticket?
