Solved 3CX Hosted: No outbound SMS: The connection was refused. Please run a firewall check...
rmnnet
I just migrated to 3CX hosted a week or so ago. I've never used SMS before other than to play around a bit.
I just added a Twilio SMS number. When I run the test in UI, I get " The connection was refused. Please run a firewall check to identify the issue. Messages cannot be received until this issue is resolved."
Verified that my API/Credentials are correct.
I can send SMS through that service/DID just fine.
I ran the firewall checker, and it passed.
Hi!
Just to make sure I understand correctly, you can send and receive SMS messages fine through Twilio, but when you press the "Test" button, you are getting the error:
"The connection was refused. Please run a firewall check to identify the issue. Messages cannot be received until this issue is resolved."
Did I understand correctly?
@rmnnet can you please check this now and provide me a feedback ?
Also restart services of the pbx or system service and check again.
Bluebox Global
