3CX in DMZ: Port Forward vs SBC?
oguruma1218
Forum User
I've been running 3CX for a small home office for a while. I've been using a Raspberry Pi located behind my firewall. It works fine, but I want something a bit more robust and secure.
I'm going to install this on a KVM and place that machine in a DMZ.
I'm using PfSense as a Router. I have 3x Yealink phones and I use the softphones occassionally.
What's the best way to get the SIP traffic from the LAN to the DMZ interface?
The Raspberry Pi SBC doesn't seem like a bad way to go, since I won't have to punch holes from the LAN > DMZ. However, it creates another point of failure (the SBC itself).
Of course, I could just punch the holes from DMZ > LAN and forego the SBC, but I suppose that's theoretically less secure (or is it?).
Any input on this?
If you configure the pfsense per the guide provided here, you do not need to use a DMZ at all for security, it really wouldnt benefit you at all. Just put it on the LAN and be careful with the port forwards.
Boblatino
