3CX in Google cloud stopped
martytheman
Hi , we've had 3cx working in google cloud for months , this morning we got emailed the following:
3CX Service notification
Following service(s) were stopped recently:
3CXPhoneSystemMC01 (10.152.0.2)
I tried restarting the VM , and it appears to be going, and I can ssh into it - but I can't access the URL etc.
[mycompany].3cx.co.nz
Ideas?
Did it come up? It will take longer to come up than ssh. I would give server more ram. My pbxexpress on azure had the same service crash occasionally and that fixed it.
Really I also tried and could not. There are times I can not create in Google, I'm using AWS, it has worked very well and I indicate. It gives a little more work, especially the first time, but following the tutorials of 3cx itself, will not have difficulties.
When creating the environment, instead of selecting Google, select AWS, a link will appear with the tutorial.
Hey what instance size are you using?
Since you can access the instance via ssh check the status of the 3CX management console service.
Code:
service 3CXPhoneSystemMC01 status
If the service is down try to start it by using
Code:
service 3CXPhoneSystemMC01 start
gmacinit
