3CX INSTALL ON RUGGEAR360
NONO1616
I Can't install 3CX app on ruggear360 because I dont have PLAY STORE on it, and I dont know how to install playstore on this phone (android 10).
Would you have a trick to help me ?
Hi NONO1616,
If its running android, you could try to download Aurora Store.
As an alternative, I have included the latest 3CX APK file from the Google Play Store to this message (it's zipped, so you have to unzip it first).
The only thing is that you have to manually update the app every time a new update is released.
You can grab the latest APK files from the play store using for example evozi.
Hope this helps you.
Thanks JustBoyke I will try on this solution
cvanderzwan
