3CX Installation Error with Postgres SQL
amanjuman
Trial User
I'm trying to install 3CX on Debian 10, and when I tried to install it getting this error
Bash:
System.Exception: Error in CreatingCloudServerManagementDatabase.sql: 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) ---> Npgsql.PostgresException (0x80004005): 22023: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) at Npgsql.NpgsqlConnector.g__ReadMessageLong|194_0(NpgsqlConnector connector, Boolean async, DataRowLoadingMode dataRowLoadingMode, Boolean readingNotifications, Boolean isReadingPrependedMessage) at Npgsql.NpgsqlDataReader.<>c__DisplayClass41_0.<g__ReadMessageSequential|0>d.MoveNext() --- End of stack trace from previous location --- at Npgsql.NpgsqlDataReader.NextResult(Boolean async, Boolean isConsuming, CancellationToken cancellationToken) at Npgsql.NpgsqlDataReader.NextResult() at Npgsql.NpgsqlCommand.ExecuteReader(CommandBehavior behavior, Boolean async, CancellationToken cancellationToken) at Npgsql.NpgsqlCommand.ExecuteReader(CommandBehavior behavior, Boolean async, CancellationToken cancellationToken) at Npgsql.NpgsqlCommand.ExecuteScalar(Boolean async, CancellationToken cancellationToken) at Npgsql.NpgsqlCommand.ExecuteScalar() at PostInstall.DBConnection.ExecuteScriptInternal(NpgsqlConnection connection, String sqlQuery, IDictionary`2 parameters) at PostInstall.DBConnection.ExecuteScript(String sqlQuery, IDictionary`2 parameters) at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) Exception data: Severity: ERROR SqlState: 22023 MessageText: new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII) Hint: Use the same encoding as in the template database, or use template0 as template. File: dbcommands.c Line: 396 Routine: createdb --- End of inner exception stack trace --- at _3CXCloudDBManager.DbConnectionExtensions.ExecuteScript(IDBConnection connection, Object configurationStructure, String scriptText, Boolean asResourceName) at _3CXCloudDBManager.CloudDBManager.CreateCloudServerManagementDatabase(IDBConnection superuser, CloudServerManagementDatabaseConfiguration configuration) at PostInstall.SetupExecutor.CreateCloudServerManagementDatabase(CloudDBManager cloudDbManager, DBConnection templateConnection) at PostInstall.SetupExecutor.CreateDatabase(Action`1 stateChanged) at PostInstall.SetupExecutor.ExecuteSetup(SetupSettings setupSettings, Action`1 stateChanged, Action`1 errorNotifier) at PbxWebConfigTool.PbxSetupService.CreatePbxInternal(SetupSettings settings)
this is my host file.
Bash:
cat /etc/hosts
127.0.0.1       localhost
127.0.1.1       localhost.localdomain fqdn.domain.tld fqdn
X.X.X.X   fqdn.domain.tld fqdn
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
How can I fix this?
Postgres log
Rich (BB code):
root@tunnel:~# tail -F /var/log/postgresql/postgresql-11-main.log
        CREATE DATABASE masterprofiles
          WITH OWNER = phonesystem
               ENCODING = 'UTF8'
2022-04-27 13:19:10.254 +06 [7461] phonesystem@template1 ERROR:  new encoding (UTF8) is incompatible with the encoding of the template database (SQL_ASCII)
2022-04-27 13:19:10.254 +06 [7461] phonesystem@template1 HINT:  Use the same encoding as in the template database, or use template0 as template.
2022-04-27 13:19:10.254 +06 [7461] phonesystem@template1 STATEMENT:  --Initial setup
        -- master profiles database
               ENCODING = 'UTF8'
Are you using the 3CX Debian ISO image, as this is the only supported way of installing 3cx
No just on a fresh Debian 10 which I used before and worked fine.
Just fixed the issue with the following steps.
Code:
sudo service postgresql stop
Code:
nano /etc/postgresql/11/main/pg_hba.conf
#Comment existing line and add bypass
Code:
#local   all             postgres                                peer
local   all             postgres                                trust
Code:
sudo service postgresql start
Code:
psql -U postgres
First, we need to drop template1. Templates can’t be dropped, so we first modify it so t’s an ordinary database:
Code:
UPDATE pg_database SET datistemplate = FALSE WHERE datname = 'template1';
Now we can drop it:
Code:
DROP DATABASE template1;
Now its time to create database from template0, with a new default encoding:
Code:
CREATE DATABASE template1 WITH TEMPLATE = template0 ENCODING = 'UNICODE';
Now modify template1 so it’s actually a template:
Code:
UPDATE pg_database SET datistemplate = TRUE WHERE datname = 'template1';
Now switch to template1 and VACUUM FREEZE the template:
Code:
\c template1
Code:
VACUUM FREEZE;
Code:
exit
Code:
Now change back as it was
Code:
Code:
Reference: https://stackoverflow.com/questions...coding-utf8-is-incompatible/16737776#16737776
Carlos - EC Mates
