3CX is the First PBX to be Listed on Google Marketplace
StefanW
It’s Now Even Easier to Deploy 3CX in Google Cloud 3CX is now an official Google Marketplace Partner. What does that mean? You can easily deploy 3CX through Google Marketplace directly into your Google Cloud account. Google Marketplace is Google’s official online store for web applications and third-party software. 3CX is the first PBX t...
Very nice, setup is super smooth and quick. However, I'm getting Full-Cone Fail at the Firewall Check for all ports 9000-10999. Everything on the Google Cloud Project looks OK.
Deployment tool set the ports as TCP; I changed them to UDP it works.
Reactions: YiannisH_3CX
the scrip features UDP and TCP ports, did you happen to make a screener from the ingress rules before the edit to we can check the deployment logs of yours?
I did not, I will spin up another instance and see what happens this time.
we checked the deployment script and it defines it as "undetermined" which should default to UDP. we have hardcoded it now to UDP to be saved. If you could run it once more and let us know would be great (you might need to delete this rule before). Thx for the report anyway.
This looks to be resolved now. Thank you team!!
11192
AshleyStokes
