3CX KHOMP KMG 200 Gateway Integration
Emeka Percy Nnochirionye
Is it possible to integrate the KHOMP KMG series gateway with 3cx? I have tried setting it up but when I hit the 'Generate Config' button, it displays a 404 error.
Thank you.
Hello @Emeka Percy Nnochirionye
Please note that currently only Khomp UMG gateways are supported. The Generate config button will try to access the gateway directly and if it is not able to do so as this is a different series gateway you will get an error. I would recommend getting a supported device from our supported devices list
https://www.3cx.com/support/ or you will have to manually register and configure the device to the PBX. Alternatively you could post this as a feature request to our ideas section of the forum https://www.3cx.com/community/forums/3cx-ideas/ . All posts are reviewed by their corresponding Departments and, if feasible and voted for by other users as well, may be implemented in an upcoming service pack or update.
Ok thanks YiannisH_3CX.
Glad i could assist
Sugu
