3CX LTE Provider
Glenn Mula
To whom it may concern
Is it possible for 3CX Messaging to support Local LTE Service, instead of the listed providers? Bandwidth, Flowroute, HostProfis, Telnyx and Twillio.
One of our ISP providers supports 3CX SIP Trunks.
Can this be the same with SMS as well? Or only those 5 providers, provides SMS feature?
Hi @Glenn Mula,
I'm afraid that at this time, no it is not planned. If we later do add any more SMS providers, I'm sure that we will be making announcements in our Blog.
What if I use LTE Services with an FXO device, will it help or it only can be used for calls only?
Hi @Glenn Mula,
The providers are hardcoded so I'm afraid that won't work.
I researched and spoken to beronet support.
Their products support LTE SIM and they are compatible to 3CX.
Is there a way where we can use BeroNet for 3CX SMS Messaging Feature? As it can be used VoIP, can it also be used for this feature?
No, 3CX only supports a predefined set of SIP providers only. You might be able to use Hosted SMS from Twilio and Telnyx, but that will depend on your SIM provider.
j.hereijgers
