3CX Management Console leaking memory
choimarc
I'm using 3CX v15.5 SP4 on Debian. I was working with the Call Control API when I noticed that the 3CX Management Console seems to be constantly using more and more RAM. Is this normal ? Should I be concerned about this ?
Thanks.
Marco.
Hello @choimarc
There were some improvements regarding this included in SP5 so the first thing i would recommend is to upgrade to SP5 and see if you still experience the same behaviour.
I have read a lot in the forum concerning the cpu specific issue with the netcore version but I'm not using any of the problematic cpu. Will sp5 still help me in this case ?
Thanks, I have read the release notes. I will try to upgrade asap. Thanks for the advice !
Glad i could assist. Let us know if that resolves the issue
Will do
megalmazan
