3CX Multi Tenant feature inquiry
Abdullah Elsaied
Hi All,
in case I have many customers, is there a way to Install single 3cx Node and separate between each customer (Data, Ext, Trunks,....etc) so each customer can see only his data and add to it.
No, this is not a feature of V15.X. You will need to do a separate install for each customer.
Hi Davil,
Thanks, I have another question could I install 3CX in my private Cloud, not Google or Amazon?
Hi Davil,
So, I would have a multi-tenant solution that can manage the service across different service providers
Where I do not recommend this, I have known partners getting around this issue by segregating extension groups for each tenant using a single (large 3CX installation) and simply hiding each group/tenant from seeing one another.
This does provide issues in that you cannot block extensions from calling one another locally if members guess extension numbers so it is not a true multi-tenant solution.
Just spin up separate 3CX instances.
You can install 3CX where ever you want - your private cloud which essentially is a the same machine as a physical server nowadays. Actually more available, achievable and also customisable to your needs.
But the relation is
1 3CX Install <-> 1 physical / virtual instance <-> 1 client.
The feature eddv123 correctly mentioned is more suitable for Extension Groups. Granularity of groups, extensions and visibility within the same PBX domain.
Reactions: craigreilly
gmacinit
