Solved 3CX not using e-mail template for VoiceMail notification.
Hubert
SOHO User
Modified VoiceMail template - prepended THISISTEST to Subject:
Enabled "Send email notification only" in User Voicemail settings:
When I receive an e-mail the subject is:
There is no THISISTEST from modified template in the Subject field. Do I have to do some reload after template modification?
Hubert
Hi @Hubert,
I tested this and found that the services require a restart, then it works. Give it a try and let me know.
OK. Which service should I restart?
Hi @Hubert,
Restart them all. Also just a note, in Update 3 this should be fixed.
Restart of "3CX PhoneSystem 01 System Server" service was enoguh. Notification picked modified template after this.
Great to hear it @Hubert. If you need any further assistance feel free to open a new thread.
Bluebox Global
