Solved 3CX Notification: 3CX Debian OS Update Failed
safemode
Hi team
I have one of the systems we managed failing to upgrade, I have attached the log files, any clues to how to resolve this issue would be very much appreciated
kindest regards
Anthony
Hi there,
Please remove the appstream package, reboot and then try again.
It should work, but if it doesn’t, take a full backup of 3CX, setup a new Debian 10 machine, shut down the old instance and restore the backup on the new one. (This is the recommended way, to start fresh and avoid any short/long term issues)
Reactions: safemode
Thanks for the quick reply, are you able to confirm the command to remove the appstream package. I ran a quick search of the forum and found several different commands so I am not sure which one to use with the standard 3cx Debian 9 iso.
Kindest regards
Anthony
That would be
Bash:
sudo apt-get --purge remove appstream -y
thank you so much, that worked perfectly.
Excellent :)
I will mark this topic as solved and should you need anything don't hesitate to create another topic.
Have a great rest of the day.
Reactions: NickD_3CX
Bluebox Global
