Solved 3CX notifications from [email protected]
Dupablada
Hi All,
Kind of at my wits end here trying to work this one out. Last night our SIP provider had some issues which caused a number of our client instances to send out notification emails about registration issues (opened our ticket system to 300+ notifications this morning. The issue has since been resoled by the provider. However we have one instance that just keeps sending through registration and dns issue notifications. This is not the case as the instance is all working fine.
For the life of me I can't stop these notifications coming through though. I've turned off all the notifications in the 3CX instance they still come through I changed the smtp address from 3CX to an O365 account the notifications still comet through from [email protected] I've remove the instance from the instance manager incase it was something to do with that they still come through.
I've restarted the machine running 3CX twice now and restarted the services along with running any updates for Debian and they still come through. Something must be stuck somewhere but I just don't know where to look. Could this be an issue with 3CX's notification service. I really don't want to pay £90 to call them up and find out it's an issue on their end which at this point it seems like it might be. The only way I could tell for sure is to shut the instance down completely for 20min or so and see if we still get them through which I might have to do this evening if this does not get resolved.
Any thoughs would be greatly appreciated.
It could be that the emails are queued in their SMTP server and have been slowed down to prevent spamming. @JohnS_3CX
Yeah I think it must be an issue on their end. I've sent them a message via their contact form on their website. Will see if they come back with anything. If anyone else has any other thoughts please do send them across.
@Dupablada can you PM me with the email address where the emails come to ?
I want to check our SMTP servers and I will give you a feedback.
Sure will send it across in a min. I contacted the Channel Manager - North UK as well to chase this up as it's the only number I could find to make contact with you guys. There seems to be a ticker number now for it ticket#6419494
@Dupablada as per our private conversation and as found from our SMTP Servers, there is no issue on our side as each Trunk on the PBX side will send a notification for change of status as below example.
If you have 30 SIP Trunks on the PBX side, then you will receive 30 emails ( 1 for each trunk ) every time.
If you have multiple PBXs with the same email address for alerts and the same Trunk Provider, this can lead to this situation.
Also it is highly recommended to check your SMTP and ensure that it will not reply back to us anymore message " 550 we do not accept mail from this address "
Example :
Trunk -L:10028(xxxxxxxxx - xxxxxxxxxxxxxxxxx) has been changed - xxxxxxxxxxxxxxxxx.3cx.co.uk
Trunk -L:10016(xxxxxxxxx - xxxxxxxxxxxxxxxxx7) has been changed - xxxxxxxxx - xxxxxxxxxxxxxxxxx.3cx.co.uk
Trunk -L:10000(xxxxxxxxx - xxxxxxxxxxxxxxxxx) has been changed
Trunk -L:10008(xxxxxxxxx - xxxxxxxxxxxxxxxxx) has been changed - xxxxxxxxx - xxxxxxxxxxxxxxxxx.3cx.co.uk
Trunk -L:10019(xxxxxxxxx - xxxxxxxxxxxxxxxxx) has been changed - xxxxxxxxx - xxxxxxxxxxxxxxxxx.3cx.co.uk
Kayla Norris
