3CX on Android - filter personal contacts
Sean Williams
Hi team,
I have an issue where if I don't give 3CX for Android permission to access my contacts, then when in the contacts tab I can't select any contacts because the popup doesn't appear - even if they are internal extensions, system-contacts or personal contacts.
If I switch on the permission, then the popup happens and I can ring, however I want to be able to call out from my contacts list but filter out my personal contacts from the list.
How do I go about achieving this?
Hello @Sean Williams
We are currently looking into this issue. Thank you for reporting. I will let you know once we have an update.
Reactions: Sean Williams
Any update on this one? Thanks
Please note that this has been fixed in the latest beta release. If no issues are found it will released as a stable release in the near future.
Mahlon
