3CX on premise
georgi0
Hello.
Is it possible to have an alternate IP address in my network for a debian installed 3CX system?
also, what is the default password to gain access to my system? once installed on the machine i cant do anything else with it.
thanks
What do you mean by alternative IP address? The access data is set during installation.
i meant if it;s possible at all to alter the installation IP address after the installation.
Sure, its on dhcp if you dont give them a fixed ip.
well i gave a fixed Ip address and now i need to move it to a different network...
Than you know how to do it. Just give them an IP address from the new network or put it back to dhcp.
Reactions: N_G
The root/SSH password is set during installation.
DejanMDS
