3CX Only works Locally
clkool
Forum User
As stated above 3CX only works Locally now. We have a Server setup onsite, but a few things happened to make it not work. So here is a breakdown summary of what happened.
Summary:
IT Person sets up 3CX everything Works Perfectly
About a Year latter Router Dies
Bought New Router
Setup New Router
IP Was Changed
Port Forwarded 3CX with New Router
Changed Select Network Card Interface to correct IP in Network Settings
Ran Firewall Checker can do everything, but only locally (Below is a picture of it at the bottom). If i want to run 3CX from my home it fails to Register.
So basically my IT guys is extremely busy now and can no longer help me on this so i have to do this myself. I'm very confused why it's not working. My hunch is i need to redirect the IP to the new IP that we changed, but i can only find one place to change the IP in the 3CX System Manager which is the Network Settings and Select Network Card and the Extensions Phone Provisioning section.
From 3cx support:
You will need to navigate to Settings / Network and set the "External IP Configuration" to "Dynamic Public IP (IP changes)". Then restart 3CX services. If you are using a 3CX FQDN wait for the DNS propagation. Once all checks out you can switch the IP configuration back to static.
You used to have to reinstall to change Public IP... but now this is the way.
Are you using a 3CX FQDN and does it resolve to your WAN IP?
Reactions: Saqqara
Can you access the management remotely via fqdn.
What version of 3CX are you running ?
Ok so anyways for some weird reason it started working today. I'm not 100% sure, but i think when i first retested it did not immediately start working, but now it's working now i'm not really sure what happened.
Thanks everyone.
3K8iMGWviZ
