3CX Outbound Rules on Startup Pro so do not have to dial a 1 to call a number
MagicshineLLC
Hello we have startup pro and use Voxtelesys and are trying to configure it where we do not have to dial a 1 to make a outbound call. can someone point us in the right direction please can only find stuff thats not startup pro related
Hi there
Regarding your question, with 3cx start-up, outbound rules are created automatically in the backend and can not be changed.
It is therefore required to dial the full number in order to dial out.
Hello @MagicshineLLC
In addition to what my colleague said, you should be able to dial 10 numbers using VoxTelesys but you may need to adjust a setting in your VoxTelesys account. I would recommend contacting VoxTelesys support so they can further advise.
Hey @MagicshineLLC,
We adjusted your account to National format for outbound calling, can you retest your calling it should support the following:
NPANXXYYYY
1NPANXXYYYY
+1NPANXXYYYY
Hey @MagicshineLLC ,
Just wanted to check in and see if you were able to retest? If you are still having issues please create a support ticket from the portal or email and we will do some live testing to see what formats we are seeing on the call invites.
SG_F7
