Solved 3CX PBX Express
stsvoip318
I may be a little behind the curve on this, but what happened to pbxexpress.3cx.com? I've deployed 10+ instances with this URL and it installs server into my Amazon Lightsail account. Did it get moved? Is there somewhere else I am supposed to go to now? I've literally searched for this all morning and can't find anything on it.
Thanks in advance!
@stsvoip318 pbxexpress.3cx.com has been deprecated.
Now you can do the same from your customer.3cx.com portal and on the right side of the key you may select option to Self Host if you want to setup the PBX to your own Hosting Provider. Check attached screenshot.
Or you can select option " Deploy to Hosted " for new keys and " Migrate to Hosted " for already installed PBXs.
This will trigger the PBX to be hosted by 3cx.
Reactions: stsvoip318
Awesome. Thanks for the prompt response. That was exactly what I was looking for!
