Solved 3CX PhoneSystem 01 Management Console high CPU utilization and crashing
simplilearn
I am running with 3CX enterprise license 16.0.9 in Window server 2019. There is around 1200 extension is configured. User using web client to take calls. I am using 3cx since last 6+ years but facing this issue recently, where the CPU utilization is going high. 3CX PhoneSystem 01 Management Console is crashing.
Hardware Configuration : Bare Metal Server
64GB RAM 2 x Intel Xeon 4208 2.4Ghz processor (16 cores total) with SSD
Please help to resolve the issue.
Hi @simplilearn,
Your HW specs seem great. A couple of questions:
  1. Have you ensured that Windows Updates installed?
  2. Are you using any 3rd party softwares installed, such as Antivirus software etc?
  3. Have you checked the 3CX Management Console Activity Log to see if something was leading up to the high CPU usage?
  4. What does the Windows Event Viewer say? Was there a crash or was the service stopped for some other reason?
Hi Vasilis,
The CPU usage is normal now after purging the contacts from the PBX has settled the CPU usage to about 35%.
Regards,
Simplilearn IT Team.
Hi @simplilearn,
How many contacts did you have added to the system when the CPU was running high?
We found the issue is with the contacts which were synced with salesforce CRM and now no more is in use in 3CX.
We purged the contacts after taking backup, now it is reduced to 10% if calls are reaching 100 even.
Reactions: VasilisV_3CX
Great to hear @simplilearn, thanks for sharing that for others who may face the same issue. If you require any further assistance, feel free to open a new thread.
devo.it
