3CX-Salesforce Integration Contact Matching Issue
George_WB
Hi there,
I am having issues with my integration during CRM Query as when our agents dial a number with 00 in front, in the query it seems that 00 is ignored and this creates some unwanted contact matches.
For example 12345678 is Contact A and 0012345678 is Contact B
An agent calls Contact B and we see this:
Request text: https://xxx.salesforce.com/services/data/v37.0/search/?q=FIND {12345678} IN PHONE FIELDS RETURNING
This means that call log instead of being logged in Customer B, it gets logged in Customer A.
Is there a way to pass all digits, even 00 to prevent this kind of mismatch?
Thank you!
First, it looks like you don't have the latest version of the Salesforce template, as you're pointing to an old API version. Please go to the 3CX Console > Settings > CRM Integration, and you will see an update for the template.
Said this, you can change how many digits are used in the contact lookup from the 3CX Console > Advanced > Contacts > Options > Exact Match. However, the Salesforce web service not always returns the contact details when you use the full number, so please make some tests after you do this change.
