3CX SBC multiple addresses - Failover
daveatgower2
Is it possible to have multiple SBC addresses for the IP Phones on v18 Hosted? For example, if our SBC goes offline we would have another one to failover to but do not want to manually change the IP addresses for each phone?
Does 3CX offer the SBC HA Cluster for Windows?
Reactions: daveatgower2
that ends that... thanks for the replies!
What is the fear running sbc on raspberry pi or debian, we known it is a difference operating system if you are not use to it.
Setup sbc on Debian or pi as per info in the link above, when done the system is setup and leave alone - it just works
We have moved all of our instances of 3cx and sbc to Debian - best move we have done
Less management than windows, no more windows updates
Installing into a VM makes it pretty easy to get going. I realize Linux is "different" but there's really nothing to do on it except initial set up.
An alternate recovery path upon SBC failure is to install an SBC using the same LAN IP and then everything should just reconnect.
Silent_Guru
