Solved 3CX Shutdown Command from Debian Command Line
tony28
Forum User
What is the command to shutdown 3CX services from the command line in Debian without shutting down the server?
Figured out how to stop 3CXStopServices.
What is the command to start the services one by one?
I need to start the services separately for troubleshooting.
You need to use the Debian command for that. A simple google search should tell you a few ways you can start/stop individual services on Debian.
I very commonly used way is:
Code:
service <service name> start|stop|status
e.g.
Code:
service 3CXPhoneSystemMC01 start
which would start the 3CX Management Console service and all other services that it depends on.
ICTSupport@bedfordgirlssc
