3CX Softphone Version (20.0.460.0) - No audio for the first call of the 'day'
Jaydan
Hi All,
I'm having an odd 'bug' with our 3CX Instance.
3CX Softphone Version: 20.0.460.0
3CX Hosted Version: Version 20.0 Update 1 (Build 731 Release)
3CX license (NFR): Enterprise
I have upgraded our NFR instance to V20, and have started using the 3CX Softphone downloaded from the Microsoft Store.
For my setup I use a Bluetooth headset connected to my PC + 3CX Softphone. I have noticed since the update the very first call I make OR receive there is no audio. (I can't hear them and the caller cannot hear me.)
My current workaround is to make the 'first' call of the day from my personal mobile to our 3CX instance. After the first 'no audio' call is complete the audio works correctly.
Any ideas if there is a fix for this ?
Happy to provide more information if required.
Thanks !!
Is the headset already active before you start your first call?
Reactions: Jaydan
Yes, I double checked this morning, It is displaying as selected in the 3CX softphone 'Settings' page. I still had the same error. I'll try again tomorrow using the Webclient instead of the softphone.
Try to hear some sound before your call... YouTube or something else. Test again.
Reactions: Jaydan
Will do ! Thank you for the suggestion, I'll reply with results tomorrow.
Reactions: bitn2
Is there any news on this topic? We have the same issue with our Jabra headsets. Maybe it's a hadware issue, but we can't find any power saving options or anything similar to turn them off.
When I go to the audio settings in 3CX in the morning and 3CX gets a new impulse for its sources, the first call always works.
Therefore, I actually believe that 3CX wakes up the Jabra headset on the first call, so that it only works on the second call of the day.
Thats a Jabra problem... you headset is in standby and not connected to your pc. 3CX cant wake up the headset.
Reactions: Jaydan
Test with Headset model: 'Creative' Sound Blaster Jam V2 Bluetooth Headset.
I have done some tests and am still having the same issue.
I can confirm both earpieces are playing audio from other sources prior to the first call, the first call will still have no audio.
I confirmed before the first call that the correct input and output was selected in the softphone's settings.
I'm going to try and find another headset to test with.
*EDIT*
Softphone Version 20.0.491.0
This morning we also tested this with YouTube. The sound was there immediately and the song was played. This means that the headset was not in sleep mode or anything similar. We did this on both sides. Then we made a call. As usual, it didn't work. After hanging up, we tested the second call and it worked. So the problem with the first call must actually come from 3CX. Especially since Jaydan doesn't use Jabra.
Firewallcheck ok? UDP Timeout on your firewall?
Have you found the cause of the issue? Also have the case for a customer, but I use exact same hardware and I never had problem, but I always listen music arriving at the office so the headset is always on when I get the first call.
Same questions here.. Firewalcheck ok? UDP Timeout on your firewall?
