3CX Step-by-Step SIP Trunk configuration to Avaya CM S8500
minion
New User
Hey all, new to the SIP world and new to the 3CX product, trying to learn it to see if it might be a replacement down the road.
Does anyone know where I might find a step-by-step guide to create a SIP trunk between the two allowing extensions on both sides to dial the other?
Hi @minion
I don't think you will find a step-by-step guide for this as neither side has tested something like this. You could create a bridge on the 3CX side and connect them that way or you could create a generic SIP Trunk and manually set that up. Both methods will require some knowledge of the 2 products so someone who has already done this could provide instructions or you could speak to a 3CX partner and see if they can assist you.
I had just seen various comments in the threads with people having issues and tips to resolve them, but I might have missed the information on the actual configuration. So was kind of hoping if I missed it I might be directed toward it, or maybe this subject might be a good place for future searchers.
Senergia
