3CX Supported Gateway
Roopesh Balakrishna
Dear Support,
We are using 18.0 update 3 3CX server on our environment, Currently we are using patton voip gateway. Due to unavailability of patton gateway we are planning to configure dinstar 1000 4 port gateway. Kindly advise if the mentioned gateway is supported on 3cx also we would like to know about high end gateway stability with dinstar if we go with 32 port.
We have been informed from supplier that patton has stopped distribution to UAE region. Kindly advise.
Regards,
Roopesh Balakrishna
Upvote 0
We dont support any new gateways. You can configure them manually with the help of Dinstar support. We cant make any comments if it works well or not..... I would suggest using Grandstream in stead.
Finatra.us
