3CX to Freshsales journaling as a call rather than a note
Infinite Networks
Gold Partner
Is there anyway to map a 3CX extension to a Freshsales user so the call is journaled as a Call in Freshsales rather than being added as a Note?
I've read through a few posts but its not clear and Freshworks support haven't been helpful.
I can see the phone call option in the XML template but it doesn't seem to work.
<Scenario Id="ReportCall" Type="REST"> <Request SkipIf="[ReportCallEnabled]!=True" Url="https://[Domain].freshsales.io/api/phone_calls" MessagePasses="0" RequestEncoding="Json" RequestType="Post" ResponseType="Json"> <PostValues> <Object Key="phone_call"> <Value Key="call_direction" If="[CallType]==Inbound" Passes="0" Type="String">true</Value> <Value Key="call_direction" If="[CallType]==Missed" Passes="0" Type="String">true</Value> <Value Key="call_direction" If="[CallType]==Outbound" Passes="0" Type="String">false</Value> <Value Key="call_direction" If="[CallType]==Notanswered" Passes="0" Type="String">false</Value> <Value Key="targetable_type" Passes="0" Type="String">[Contact::EntityType]</Value> <Object Key="targetable"> <Value Key="id" Passes="0" Type="String">[Contact::EntityId]</Value> </Object> <Object Key="note"> <Value Key="description" If="[CallType]==Inbound" Passes="2" Type="String">[[InboundCallText]]</Value> <Value Key="description" If="[CallType]==Missed" Passes="2" Type="String">[[MissedCallText]]</Value> <Value Key="description" If="[CallType]==Outbound" Passes="2" Type="String">[[OutboundCallText]]</Value> <Value Key="description" If="[CallType]==Notanswered" Passes="2" Type="String">[[NotAnsweredOutboundCallText]]</Value> </Object> </Object> </PostValues> </Request> <Variables /> <Outputs AllowEmpty="false" /> </Scenario>
Kayla Norris
