3CX unable to locate package
tcannon
New User
I am trying to install 3cx on my raspberry pi. When I run the correct command the terminal says it is unable to locate the package. I have reflashed my pi like other threads have said.
Reactions: NickD_3CX
You are apparently running Debian Bullseye which is not supported.
As above,
In my post I did highlight to you , download the correct operating system - step 2.1 of the url
I used a wireless network to download 3cx. I then decided to static the raspberry pi and now it won't connect to 3cx. WIll I have to redo the process with the static ip?
Now upon using the static ip, I cannot get into my 3cx machine by ip address. Any suggestions?
Already done all of this.
If you followed this then you wouldnt be having problems.
Format your SD card and try again.
gmacinit
