3cx V11 restore, cant connect to HTTP for updates
Wes
We have a machine that is about to have a HDD failure. Read the instructions from the prior user to restore, which seemed to not have any problems. When trying to Activate or Update to the other service packs, it cannot connect to the HTTP server. When looking this problem up, it seems there was an update a while back that updated the SSL cert to allow future communications. Is there a download somewhere that includes the needed Certificate, or some other work around so I can update? Thank you in advance.
Also, I tried going to the http://www.3cx.com/downloads/3CXPhoneSystem11.exe to see if it would work, but I get redirected to download the current version...
Being so old, I doubt 3CX has the update services for this version.
Why do you not upgrade to ver 15.5 ?
@complex1 - I will give this a whirl tonight, thank you!
@Saqqara - We are still using some old hardware here, looking to replace everything soon as we will move to the cloud, just came at a bad time...
gmacinit
