3cx v18 nicht verfügbar
Isen Tiefbau AG
Hallo
ich versuche die 3cx v18 im Playstore zu finden. dort ist aber nur die v16 verfügbar. Hat jemand einen gültigen Link?
Hi @Isen Tiefbau AG , you can install the Beta from within the Google Play Store. Please search for "3CX" , check on the details, and you will find the option there to join the Beta.
Sorry it's not possible within a managed store.
The current app you find available in the App Store (the non-Beta), despite it being a v16.x.x.x application, will work just fine with 3CX V18 installations.
Unless there is something specific you want from the v18 version of the app, install the current stable one. Once the v18 version of the app exists the Beta stage, all your devices should update automatically.
DejanMDS
