3CX V20 Ip address changed, firewall test failed
houseofdreams
Hi. We recently moved and I upgraded the network in our new home, to use VLANS, to keep things more seperated/secure. Previously, the (on premise linux) 3CX server was installed at the IP 10.10.10.160, now the VOIP Vlan is located in the 10.10.50.x range, the 3CX server is 10.10.50.2.
I also have a PFsense firewall that was configured following this tutorial https://www.3cx.com/docs/pfsense-firewall/ This worked fine, when the IP address was in the old ip range. I changed all the IP's in this tutorial, to reflect the new IP range.
After some trial and error, I finally got the FQDN link to work, also the first IP phone I connected is working, incoming/outgoing calls are fine.
The only thing I don't get, what I'm doing wrong, is when I do the firewall test on the 3CX dashboard, I get the following "failed" responses
Help is appreciated!
Diogo Maia
