3CX V20 Update 10 – Firewall Checker Fails Due to Missing STUN IP in Official Documentation
cpe90
Hello 3CX Team,
After upgrading our 3CX system to V20 Update 10 (Build 1801), the Firewall Checker repeatedly failed the Full Cone NAT tests for UDP 5060 and multiple RTP ports.
We're using a Palo Alto PA-1420 firewall with restricted inbound and outbound rules based on the STUN server IP addresses published in the official 3CX documentation:
https://www.3cx.com/docs/firewall-checker/
During troubleshooting, we discovered that our Palo Alto was denying incoming UDP traffic from 34.73.139.160 to multiple RTP ports (9042, 9052, 9060, 9066, 9072, and 9076).
This IP address is not included in the official 3CX Firewall Checker whitelist.
After adding this IP to our restricted firewall address group, the previously failing firewall tests started passing.
I also found a German 3CX Community Forum discussion reporting a similar issue involving secondary STUN response addresses (34.159.93.50):
https://www.3cx.de/forum/threads/fi...bes-nachweislich-bei-der-pbx-ankommen.127080/
Could the 3CX team please confirm whether 34.73.139.160 is an official secondary STUN response server and update the Firewall Checker documentation to include it?
Administrators using source-IP-restricted firewall policies rely on this documentation to properly configure their firewalls without allowing unrestricted inbound traffic.
Thank you!
Hi @cpe90 during the test you can notice the domains used for the test for example:
  • resolving 'stun-sa.3cx.com'... done
  • resolving 'stun2.3cx.com'... done
  • resolving 'stun3.3cx.com'... done
  • resolving 'sip-alg-detector.3cx.com'... done
Also you can check this guide which explains what is checked during the test.
Hi Alejandro,
Thanks for your response. I checked the FQDN resolution directly on our Palo Alto PA-1420 using:
`show dns-proxy fqdn all`
The results show:
- **stun-us.3cx.com:** 34.83.212.229, 34.138.123.132
- **stun2.3cx.com:** 34.83.212.229, 34.40.164.62, 34.138.123.132, 34.40.60.101
- **stun3.3cx.com:** The same four IP addresses
- **sip-alg-detector.3cx.com:** 34.141.156.185
However, none of these FQDNs currently resolve to **34.73.139.160**.
The 3CX guide is only showing IPs 34.40.60.101, 34.40.164.62, 34.83.212.229, and 34.138.123.132.
Our Palo Alto traffic logs confirmed that the Firewall Checker received secondary STUN responses from **34.73.139.160:3479**, which were initially denied by our restricted inbound firewall policy.
After explicitly allowing that IP, the previously failing full-cone NAT tests passed.
Could you please clarify whether there is a separate FQDN for this secondary STUN response server, or whether 34.73.139.160 should be added to the official whitelist documentation?
Thank you!
The thing here is that for the Full Cone NAT test the ports must be unrestricted, please check the document I sent you.
Test 2, the 3CX server sends another request to the same STUN server. However, this time:
  • The 3CX Server marks the request with "Change IP and Change Port" set to (1).
  • This instructs the STUN server to send its response from an IP address and port that is different from the one the initial request was sent to.
  • This new source IP/Port is unknown to the firewall, which would typically expect a response from the original destination.
Firewall Checker - Example 2(Firewall Checker - Example 2)
If the server sends multiple requests without receiving a reply from the STUN server, it indicates that Full Cone NAT is not working.
Unlike Test 1, where 3CX expects a response from the server it actively communicated with, Test 2 simulates receiving data from a source that 3CX has not directly "talked to" (similar to an audio server of a VoIP provider). If no response is received, it means the firewall is blocking this type of traffic. In this case, contact your firewall manufacturer to resolve the problem.
A successful response in Test 2 would show the "Mapped-Address" as exactly the same IP and Port as in Test 1. If you wish to investigate further, check your firewall logs for traffic from the 3CX STUN server IP addresses, as the expected answer never reached the 3CX server's network interface.
ddindial
