3CX v20 Where to switch phone to use SBC
VUSALDADASHOV
Gold Partner
When I had v18 i was able easily select SBC for IP phone....
But in v20 I cannot find such an option
look. At network interface I do not have such an option
But on phones I previosly configured I do not have an option "network Interface". Instead of it I have "Routing device"
The only question: HOW to switch?
You could likely delete/readd the device to switch it's provisioning/use type.
Previously the phone was provisioned as STUN?
I misread your original post. The routing device dropdown is the SBC selection.
From no phones added, you click add phone and choose local lan, router phone, or SBC:
I have readded it
but on v18 I could easily switch between SBC and Local LAN
So many chnages....
I have readded it
So many chnages....
I don't think you can switch the type anymore without a delete/re-add, but I have not tested extensively.
Reactions: VUSALDADASHOV
Correct, you need to remove the device from the extension, factory reset and provision again.
Senergia
