3cx ver 20 pro 8
rickreeves
my report tab is missing i have tried to read on it but no go may be someone can help please i have call handling, event log but no reports
help please rick erie pa
Are you System Owner or System Admin? System Admin doesn't have access to Reports.
Reactions: rickreeves
quick question how do i become owner i did not see that as an option thankas
If you set up the system, it should be you already.
You cannot upgrade your role througn the UI.
The system owner can elevate the role to another system owner for this.
Also if you have restricted access to the Admin functions by IP, and your IP now changed, then you will not be seeing the Admin option at all - if this is the case then you must access the system from an already whitelisted IP and grant rights to the new IP(s) you are using by going to Admin->Advanced->Console Restrictions.
arneg
