3CX VoipStunt Configuration
meelad
I've configured VoipStunt on 3cx now i cannot call anywhere also i cannot receive any call i get this error call not found failed.
Please help me out with this issue.
VoipStunt is one of a whole bunch of near-identical low cost offerings from Dellmont of which I have used 2. Although not supported they do work fine with 3CX (at least for outgoing calls, I don't use mine for inbound).
So:
i) Is your trunk showing as registered &
ii) Do you have appropriate outbound rule(s) in place to direct your O/G calls over this trunk?
Hello @meelad
I would recommend using a 3CX supported provider to ensure compatibility and minimise configurations issues. All supported providers go through a series of tests and pre-configured templates are included in the PBX for easy deployment.
https://www.3cx.com/partners/sip-trunks/
Hi sorry but please can someone tellme how to create a new forumn post?
Very simple, while you are in the General section of the forum you should see a "Post New Thread" button on the top right of the screen above your name.
estrezacafe111
