3CX Webinar Wordpress Issue
Ackerworx
Issue with webmeeting on wordpres.
Installed the 3CX Webniars.
Linked everything up.
But the page that the plugin is running on is just blank.
You need to actually schedule a webinar before anything appears
OK well I go tp the webclient I create a web meeting.
I then go to the wordpress page where embedded the shortcode using a different computer and the page is just blank.
Try to deactivate the other plugins on your site. As the code of 3CX webinars hasn't been tested with the last 3 major versions of WordPress nor does it support latest PHP, it might cause problems. We had problems with both iThemes BackupBuddy and cminds tooltip glossary. After deactivating those plugins, 3CX webinars worked again. But those plugins are up2date, whereas 3CX webinars hasn't been developed further for 11 month. So the root cause might be 3CX webinars.
See also: https://wordpress.org/support/topic/webinar-plugin-issues-js-error-empty-form/
@3cx: Please update 3CX webinars to be compatible with latest WP and PHP. Thanks!
When testing today on an updated WP machine it appears to work ok, but I cannot say how it will interact with other plugins.
It might be a good idea indeed to disable other plugins as a test to see how it goes.
Subject1725
