3CX Windows Softphone V5.5 Production Release
ThomB_3CX
Staff member
Web Client configuration and Team filter in the Panel.​
Following a successful beta release, 3CX Windows Softphone V5.5 is now available for production. This softphone release introduces improved extension management, enhanced configuration options and a range of stability and usability fixes across the app.
We welcome any production feedback regarding the new stability and usability fixes. If you encounter unexpected behavior, please specify version and detailed steps to reproduce.
Nice to see there’s a shortcut for changing your own BLFs!
We did encounter one issue:
When using the 'Copy Number From Clipboard' hotkey, the app used to jump to the foreground, just like when you receive an incoming call and can press Enter to start calling immediately.
Now, the number still gets pasted correctly, but you need to manually click on the 3CX app in the taskbar before you can start the call.
Is there a new setting that I might be overlooking?
Kind regards,
Yuran
For us, the two biggest disadvantages of the 3CX softphone compared to the PWA app are:
- the missing ability, when in the team section, in the search field, to directly enter a phone number and press enter to make the call (as in the team search field of 3CX PWA),
- the ability to have a full screen view as PWA.
@3CX team, can you consider these improvements, please?
If these two cases were solved, we would use this application much more, in the meantime, we remain with the PWA for 99/100 of our customers.
regards,
kosa
