Solved 3cx with 2 default gateways
abdo abdelmordy
Forum User
Dears,
I already set up the 3cx with one public interface and another LAN interface to be able to make sip trunk with my gateways in the LAN network.
also, I have another gateways in remote sites connected directly by VPN site-to-site.
how can I configure the network so I can reach the remote sites at the same time able to access from the public interface?
You would need to check the firewall ports are open so you can traverse to each one of your VPNs.
are you provisioning phones via LAN over your VPN?
there are no restrictions at all. and this is not what I need to do I need to reach the other sites and able to access the server from the public internet in the same time.
I made it here is the magic command
Kayla Norris
