3CX won't provision to allow calls (V20)
ZJ-Kristopher
A separate issue I've noticed, the 3CX Android has stopped provisioning properly on V20. Everything is working apart from the main point of 3CX, making and receiving phone calls. I've checked the firewall/ports and everything is as it should and passed the self-test. The PWA desktop works without issue.
Currently on V20, Build 1494.
Hi @ZJ-Kristopher can you send me the logs in pm to check what the problem might be?
Any insight into what's happening? I have a very similar issue where iOS and Android 3CX Apps won't provision with v20. Also all firewall checks work.
@aragone, Please us verbose logs of both the clients and the PBX Support info via personal message to investigate.
RJenkinsROCK
