3CXObjectModel Modify user profiles
TD Rigus
There was a problem programmatically modifying user call forwarding rules (3CXObjectModel)
On the local 3cx server, I run a powershell script to change the phone to which the call is forwarded
The rest of the user's parameters are saved when changing, but for some reason the routes are not.
Well, or is it possible to re-read the data from the database (For example, by directly changing the data in sql and then calling some method so that 3cx gets it (this method works interactively through the web form, but not through the Save () method))?
Add-Type -Path "C:\Program Files\3CX Phone System\Bin\3cxpscomcpp2.dll"
$PS=[TCX.Configuration.PhoneSystem]
$PS::CfgServerHost="127.0.0.1"
$PS::CfgServerPort=5485
$PS::CfgServerUser="cfguser_default"
$PS::CfgServerPassword="passs"
$PS::ApplicationName="ContactApp"
$t=($PS::Root)
$t.WaitForConnect((New-TimeSpan -Seconds 30))
$SotrTo = $t.GetExtensions() |Where-Object {$_.Number -eq 155}
$Sotr = $t.GetExtensions() |Where-Object {$_.Number -eq 162}
$extProfile = $Sotr.FwdProfiles |Where-Object {$_.Name -eq "Available"}
$route = $extProfile.AvailableRoute
$route.NoAnswer.AllCalls.Internal = $SotrTo
$route.NoAnswer.Internal.Internal = $SotrTo
$route.Busy.AllCalls.Internal = $SotrTo
$route.Busy.Internal.Internal = $SotrTo
$route.NotRegistered.AllCalls.Internal = $SotrTo
$route.NotRegistered.Internal.Internal = $SotrTo
$Sotr.Save()
$t.Disconnect()
Why are you using powershell? This isnt supported.
you'd save yourself time by using the GUI.
I'm trying to automate the process of changing redirect rules (Now I need to change 40-50 redirect rules daily) The change script is programmatically generated - this saves a lot of time.
megalmazan
