3CXPlugin installation
honsberger
Forum User
I'm currently preparing the deployment of the 3CX PBX client installation. The 3CX client is fine so fare.
For the 3CX plugin, I understood to get first the Visual Studio 2010 runtime install before installing the plugin. This is good so fare.
The issue I'm facing is to install the 3CX plugin (3CXPlugins.x64.msi) for the TAPI and Outlook. What are the parameter to install both of them ?
To configure the TAPI (in C:\ProgramData\3CXMultiLineTapi) I have powershell script fetching the information from the Active Directory.I'm only missing the part of installation of the plugin.
Thanks for your support.
regards
david
Roman Mazur
