Solved 4G/GSM SIP supported gateways
siscom
Good Morning Colleagues
I hope you are doing good . I have a customer that needs 3CX in Nigeria where at Nigeria no landlines available so we have to use GSM/4G SIP gateway.
Do you have any suggestions which 4G/GSM gateway supported / compatible / tested successfully with 3CX ?
Thx in advance.
Best Regards
Reactions: AminuSeki
Good Morning Naveen
Thanks for your fast response . Have you tested this gateway for doing outbound / Inbound calls through GSM ?
Also for Inbound calls , Can it successfully allow DTMF (when caller press 1 or 2 or 3 while the call connected) so Queue or ring group at 3CX can work successfully (Press 1 for sales , 2 for marketing , etc ....) ?
Best Regards
Hello siscom,
Good Morning!
Yes, we have tested it before, Inbound, Outbound calls and DTMF works fine.
Thats great . May i know the maximum number of GSM supported by this model ?
Hello siscom,
Beronet device will support up to 6 SIM cards.
This device is modular-based, each GSM module can support 2 SIM cards.
For more information please visit https://www.beronet.com/gateway/volte-sbc/
Reactions: VasilisV_3CX
Thx Vasillis for your support
Kayla Norris
