603 MaxPeak Cost Exceeded
Jake187
I'm getting the following error when dialing a number. Any suggestions?
Call or Registration to 001345939****@(Ln.10000@********) has failed. ****.****.****.**** replied: 603 MaxPeak Cost Exceeded; from IP:****.****.****.****:5060
Hi there, which IP address is mentioned in this part ****.****.****.**** replied:
Is it the Ip address of your VoIP provider?
Hi Charles,
Yes that's the Sip trunk "Registrar/Server/Gateway Hostname or IP"
In this case, you can contact your Sip Trunk provider and ask them what this error is, as it is an error that is received from them.
Reactions: Jake187
Ask your trunk provider. I would guess that it is too expensive to complete the call to that area. Your provider likely does not want to complete a call that they would loose money on or it could be a different rate (like international) that you would need to approve with your provider.
My first thought was maybe the carrier is seeing excessive calling in a short period of time and are concerned about hackers placing surreptitious calls using your trunk? Just a guess. I would call your carrier right away.
Reactions: AWS2P and Jake187
mazet
