Solved Accidentally Changed Public IP
jsommers
I accidentally changed my public ip in the dashboard of my pbx express running on google cloud and can not access it anymore via webpage.
Can you access it using the public IP instead of the FQDN?
I tried but chrome said connection took too long
Are you definitely using Https and the correct port?
Can you SSH to the server?
I had to stop and restart the instance but now I'm up and running. THX
