- Joined
- Aug 1, 2007
- Messages
- 90
- Reaction score
- 1
Hello, everyone.
I currently have a 3CX setup involving a couple internal and external extensions and am experiencing the following issue, dunno if some of you ran into this:
When an internal extension calls an external extension, the call goes perfectly well.
When an external extension calls an internal extension, the calls goes perfectly well... For 30 seconds only when it breaks. I pulled out a trace from the log and you can notice a message after 30+ seconds as per the below at 22:52:32.568:
A weird 'ACK is not received' message is appearing and the call is terminated. Any way to fix this?
Any help would be appreciated,
Thanks.
W.
Code:
22:52:32.578 Call::Terminate [CM503008]: Call(27): Call is terminated
22:52:32.568 Call::Terminate [CM503008]: Call(27): Call is terminated
22:52:32.568 InviteADS::onAckNotReceived [CM503019]: Call(27): ACK is not received
22:52:00.482 CallCtrl::onLegConnected [CM503007]: Call(27): Device joined: sip:[email protected]:5060
22:52:00.482 CallCtrl::onLegConnected [CM503007]: Call(27): Device joined: sip:105@XXXXERASEDXXXX;transport=UDP
22:51:53.372 CallCtrl::onSelectRouteReq [CM503004]: Call(27): Calling: RingAll100:101Ext.101102Ext.102103Ext.103104Ext.104@[Dev:sip:[email protected]:5060, Dev:sip:102@XXXXERASEDXXXX:5060;transport=UDP, Dev:sip:[email protected]:5060, Dev:sip:[email protected]:12338]
22:51:53.362 CallCtrl::onIncomingCall [CM503001]: Call(27): Incoming call from Ext.105 to [sip:100@XXXXERASEDXXXX;user=phone]
Thanks.
W.
