Adding SIP Trunks from Providers in 3CX Free Version
Jon Tann
Please can you advise if there is anyway to add a SIP trunk from a provider that is not listed in the drop down in the Free Version of 3CX, I want to use a Gamma SIP trunk, which is listed in all other versions of 3CX but it is not listed in the free version. Please could you advise if this is possible to do or the free version only uses the providers listed.
Thanks in advance.
Jon
Hi John.
No there i s no way to do that on 3CX Free as neither Gamma or the generic template is available there. You will need to install a dedicated 3CX installation either hosted by 3CX or self hosted to be able to do so.
Hi Yiannis,
Right ok, or use another supplier if I wanted to use the frees version.
Thanks for coming back so quickly.
Thanks,
Jon
Diogo Maia
