Solved Advanced Settings in Admin Console
KLIN
SMB User
I have a SMB Pro license and am trying to set up international calling. I read that i can do this under the Advanced tab in the Admin Console. In my Admin Console (V20) the Advanced tab is not showing.
Available tabs are: Dashboard, Voice &Chat, Outbound Rules, Office Hours, Call handling, Reports, Event Log and Buy.
Can anyone please point me in the right direction?
Thanks!!
Because you have only SMB. Many views are hidden as they are "server-wide" and SMB is on a multitenant system. Thus why you only see your own stuff.
Reactions: KLIN
Thank you for explaining. Can you please let me know how i can set up international calling in SMB? Domestic calling is going fine, but international calls are not going out. Thanks for your help!!
It may need to be enabled…I recall a similar post a few months ago give or take. If 3CX doesn’t see this over the weekend open a ticket and ask them.
Reactions: Evolute IT and KLIN
Are you allowed from your trunk sip Provider first ?
I got a similar problem just because i forgot a + in outbound rule . Can you check if this is right for you?
What is the country code you are trying to dial?
Thank you all for pointing me in the right direction. It turned out that international calling was not automatically added to my SIP trunk, and I needed to submit a list of countries I wanted to enable.
The Advanced Tab not showing is not solved yet, I'll open a ticket for that.
It was a European country, but i think not dialing out will be solved when i send the enable list to SIP provider. Not sure how I can solve the Advanced tab not showing though, could that be a SMB Pro restriction?
Sip provider was indeed the issue, i've sent a list with countries to them
Reactions: AWS2P
Nice , one problem behind ;)
Reactions: KLIN
Glad to know this is resolved ;)
Reactions: KLIN
No members online now.
RJenkinsROCK
